Spark Plug Options?
TVST*R
Spark Plug Options?
Post by TVST*R »
IAP has 3 different plugs for the 124.
Lodge Golden,Bosch Plat. 2, and Bosch Platinum WR7DP.
What is the dif?
What are people useing?
T 8)
mdrburchette
Post by mdrburchette »
I've used Ac-Delco, regular Bosch and NGK with no ill effects. I tried the Lodge Golden and they lasted 25 miles, but my carb was a little rich at the time and they fouled. I tried cleaning them but it didn't help so I put the old Ac-Delcos back in and it ran fine. They may be good for fuel infected Spiders but in my opinion they were a waste of money.
I prefer the regular Bosch or NGK also. I feel the platinum foul easy and don't clean well. The benefit to platinum is long life without electrode wear, but who drives their Spider that many miles?
TVST*R
Post by TVST*R »
Mark,
What are the numbers on the:
Bosch-
NGK-
Thanks!
Tom 8)
I think the Bosch # is BPR5ES, not sure about NGK
mdrburchette
NGK should be #BP6ES
Gerard Del Monte
Post by Gerard Del Monte »
I run NGK Iridium plugs in my FI 2000, very happy with them. #BPR6EIX
