Main Caps
- 70spider
- Your car is a: 1970 Fiat spider
Main Caps
Ok this may seem like a dumb inquiry, but seeing how this is my first time rebuilding a motor I thought I would check. The main caps on the 1438 are in three different sizes, the front cap (which is obvious where it goes) and a cap that is 24.3ishmm and another one a bit smaller. When I disassembled the motor I put each cap in a zip-lock with the corresponding piston number and before I took it to the machine shop removed the bearings and put them back on in this order per instruction of the machinist. However this is where it gets fuzzy. While assembling I noticed that the cap on the rear was not holding the thrust bearings in place and I thought this can't be right. so that is when I removed the caps and measured them. So where do they go? So far this is the order in which I could come up with that makes since. #1-big front bearing cap #2  the smallest ones #3(center)- the larger one #5(rear) the larger one. It seems the all match up with the their "seats" this way. So do I have it right? Also the wider bearing without the oil groove goes in the center, right? I have the manual but it simple states "re-install" the bearing caps to 58lbs. Any help, before I continue with the pistons. Thanks for reading.
2002 Mazda Protege5
2013 Buddy 170i
2002 Mazda Protege5
2013 Buddy 170i
- Your car is a: 1975 Spider
Re: Main Caps
i dont have a 1438 in front of me but, the main caps are marked where they go. they will have a notch on one side and the stampings (numbers stamped into the top of the cap) will all face the same direction as the stamping (number stamped in the block on the rear ear) in the block. worst case if you take a picture of all the caps sitting on a labeled piece of paper 1 - 5 i can help you put them in order.
son has 78 spider
son has 78 spider
- 70spider
Re: Main Caps
BEEK, I took your info and looked for the marks. Indeed they are on top of the cap left of the stamped number (1 notch, 2 notches, 3 notches, and 4 notches). I got lucky and got them in the correct order, with a prayer, when I put them on.
Many Thanks for the info. Ill post pics when I get a chance.
Front cap
Cap 1
Cap 2
Cap 3
Cap 4
Front cap
Cap 1
Cap 2
Cap 3
Cap 4
2002 Mazda Protege5
2013 Buddy 170i
2002 Mazda Protege5
2013 Buddy 170i
