Cam Timing Specs. for Stock 2.0L Cams
I am looking for the specs. that tell where the stock cams should be ( in degrees °) when the engine piston #1 is at TDC. I found the following information "It is critical to mark the cams for full lift, and the correct position for timing with crankshaft at TDC. Degree wheel used to find exact point of peak lift and position for correct timing with engine". I can find peak lift, but the where exactly should each stock cam be positioned in relation with the crank at TDC? The cams are stock 2.0L spider cams.
- blazingspider
- Your car is a: 1977 fiat spider
Re: Cam Timing Specs. for Stock 2.0L Cams
Everything you want to know is in this this thread.
http://forum.abarth-gmr.be/index.php?topic=786.0
That was exactly the information I needed. Thank you!
