fuel pump not pumping
fiat218
Post by fiat218 »
new tank
sending unit
fuel pump
new filter
all new hoses from hard line to where ever
new gas
new clamps on hoses
blew air thu the main line and return line twice
took the fuel pump out, in stalled it ,seems to go in at the same stop and easy
but it not pumping,no gas
HELP :) thanks
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
2018 Alfa Romeo 4c Spider
AriK
Re: fuel pump not pumping
Post by AriK »
maybe the "wherever" part is the problem :shock:
Did you prime the carb? The new lines are one long pocket of air. You'll need higher rpm in order to start flow.
samakijoe
Your car is a: 1975 Fiat 124
Post by samakijoe »
I assume that you do not have an electric pump. I would use a little "starter Fluid" to get the motor
going long enough to get the fuel lines and the carburetor bowel full. Just a little squirt goes a long way.
Repeat until engines run on it's own.
A large fire extinguisher on hand is a good idea. :D
SAMAKIJOE
AKA GRANDPA GRUMPYPANTS
fiat218
Post by fiat218 »
Well. I need a new carb, so I'm getting that then I will start over and get it running
I'm going to add a new starter too
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
carl
Post by carl »
Did you use a clear filter or run the line from the carb into a container to verify there is no gas flowing to the pump? Make sure you have the hoses the right way on the pump, 50% chance to get it backwards. Forget the carb or the motor until you have gas flowing out of the pump......this is all assuming an electric fuel pump is being used.
fiat218
Post by fiat218 »
Mechanical pump
I got the hoes right
I hooked up a electric to see if it flows, it does, but I'm going to use mechanical
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
samakijoe
Post by samakijoe »
Jim said:
Mechanical pump
I hooked up a electric to see if it flows, it does, but I'm going to use mechanical...........
hoes?,.. did you say hoes??? Lucky you don't have a talk radio show. :oops: Or do you??
:roll:
SAMAKIJOE
AriK
Post by AriK »
samakijoe wrote:Jim said:
Mechanical pump
:roll:
Didn't you know that Jim doubles as talk show host Don Imus on his spare time from Fiats?
http://youtu.be/x1lnl-xD6iE
fiat218
Post by fiat218 »
Lol no talk show
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
carl
Post by carl »
Sounds like the pump is not working. Try removing the pump and working the lever arm by hand to see if it moves gas, could be the new pump is defective, I guess.
