Temp Gauge Sensor
davery
Your car is a: 1985 Spider
Temp Gauge Sensor
Post by davery »
I went out for a 15-20 minute drive tonight and the temp gauge never made it to 190. It stayed at about 1/4 of the gauge instead of the normal 1/2. Where is the sensor for the temp gauge?
Don Avery
Dayton, OH/Sarasota,FL
1985 Pininfarina
2011 Eos
2012 Mercedes E550 Cabriolet
fiat218
Re: Temp Gauge Sensor
Post by fiat218 »
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
2018 Alfa Romeo 4c Spider
fiat218
Post by fiat218 »
Page 13 shows what you are asking about
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
klweimer
Post by klweimer »
Thermostat stuck open?
carl
Post by carl »
Infrared thermometer is a great tool for checking overheating problems.
davery
Post by davery »
klweimer wrote:Thermostat stuck open?
Maybe. I felt the hoses connected to the thermostat, but none felt hot. I'm pretty sure the coolant level is good, but am going to verify anyway. Is there a way to check if the thermostat is working properly?
Don Avery
1985 Pininfarina
2011 Eos
klweimer
Post by klweimer »
If the thermostat is working, the heater hoses should get hot before the radiator hoses. Assuming the heater valve is set wide open. If everything is just warm, you might try tapping the thermostat a few times to see if it closes. For sure check the coolant level.
Kirk
RRoller123
Post by RRoller123 »
You can remove the thermostat and boil it in a pot of water on the stove, watching temp with a simple plumber's digital thermometer, but don't ever use that pot for edibles again.
fiatfactory
Your car is a: 1970 128
Post by fiatfactory »
RRoller123
Good point, the conduction might throw it off.
