I seen that on this 69. We got shock tower problems. Is it even worth fixing when is happens. I know the passander side trailing arm has a problem where it attach to the body frame
I have a feeling there more and well I'm not sure what I should do
I think the white yellow is bondo. But right below that I hit it with a hammer and there is a rust hold. The photo is on a angle
Major problem located
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
2018 Alfa Romeo 4c Spider
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
Re: Major problem located
Jim, you won't know what your dealing with untill you remove the top coatings down to bare metal. Full face shield gloves and a heavy duty side grinder with a heavy gauge wire wheel. When the coatings are removed take some photos and post them, it might not be as bad as you think. I know there are forum members who can point you in the right direction.
It is somthing that my other 69 had one small rust spot under the rocker panel. No rust other wise and then this 69 has some , I guess it where it come from
And your right I will have to grind away
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
The very first spider I went to look at was located 3 hrs. away and the craigslist add stated it was "rust free". When the lady removed the car cover there were rust blisters everywhere. I think the add should have read "rust is free".
