Coolant Hose ID measurements
architect
Your car is a: 1978 Fiat Spider
Post by architect »
Hello,
I am in the process of replacing all my hoses.. it looks like the previous owner decided to play a game of mixing and matching :roll:
1978' Fiat 124 - 1800
Will someone kindly suggest the I.D. of the hoses below:
1) larger hose from thermostat "pipe" near the exhaust manifold -> to the heater core in thru the fire wall 16mm or 5/8"?
2) larger hose from firewall heater core -> to head (assuming same as hose #1) 16mm or 5/8"?
3) smaller hose from thermostat "pipe" near the exhaust manifold -> carb (choke I presume?) 8mm or 5/16"?
4) smaller hose from carb to block (near hose #3) (choke I presume?) 8mm or 5/16"?
5) larger hose from crank case -> intake filter? 16mm or 5/8"?
6) smaller hose from radiator cap -> to overflow? 8mm or 5/16"?
Thank you!
78 Fiat 124
85redpini
Your car is a: 1985 pininfarina spider
Re: Coolant Hose ID measurements
Post by 85redpini »
with the fiat vendor price of the hoses, why would you make them, or try to find them somewhere else?
architect
Post by architect »
I just finished up swapping all hoses... here is my findings for anyone in the future.
architect wrote:Hello,
1) larger hose from thermostat "pipe" near the exhaust manifold -> to the heater core in thru the fire wall - 16mm ID
2) larger hose from firewall heater core -> to head (assuming same as hose #1) 16mm ID
5) larger hose from crank case -> intake filter? 18mm
78 Fiat 124
