Air flow meter adjustment
sigkadetm
Your car is a: 1980 Fiat spider 2000
Post by sigkadetm »
Here is what I got. I connected a exhaust gas analyzer as directed from the service manual. Disconnected the O2 sensor and backed off the throttle position sensor. Let engine and meter warm up to normal operating temperature then connected meter probe. Meter instantly went way lean then settled out to about 15 or around .1% CO. I screwed the AFM adjustment screw to about a 1/2 turn out from closing. The reading richened out to about 13.4 or around .4% CO. So I guess I have to back off on the tension wheel a few clicks so I could richen the mixture a little more to get between .5% to .9% CO. Need assurance.......
klweimer
Re: Air flow meter adjustment
Post by klweimer »
Not my area of expertise, but I'd be careful about changing the tension on the air flap in the AFM. In my mind, that will cause changes in mixture at open throttle settings, which could cause over-lean or over-rich conditions when driving (not idling). Too rich can cause problems with cat, to lean with pre-ignition. Neither good for your engine. I teed-in a digital volt meter to my O2 sensor to watch voltage output under actual driving conditions and used that to adjust the AFM. Just my 2 cents.
Kirk
KevAndAndi
Post by KevAndAndi »
klweimer wrote:Not my area of expertise, but I'd be careful about changing the tension on the air flap in the AFM. In my mind, that will cause changes in mixture at open throttle settings, which could cause over-lean or over-rich conditions when driving (not idling). Too rich can cause problems with cat, to lean with pre-ignition. Neither good for your engine. I teed-in a digital volt meter to my O2 sensor to watch voltage output under actual driving conditions and used that to adjust the AFM. Just my 2 cents.
Kirk
Kirk, is there an explanation of how to perform this procedure, that you could share?
Thanks.
Kevin
1981 Spider 2000
ORFORD2004
Post by ORFORD2004 »
klweimer
Post by klweimer »
Check out step 8
http://www.hiperformancestore.com/ljetronic.htm
Pretty good article.
Kirk
sigkadetm
Post by sigkadetm »
Adjusted air flow meter today and set it at 7% . Had to back off spring tension about 8 notches. Air bypass is open about one turn. Engine is now running super and the capacitor fix for the tachometer did the trick.
spider2081
Patron 2024
Patron 2024
Post by spider2081 »
Great to hear.. Now time to enjoy the car
sigkadetm
Post by sigkadetm »
Going to take a ride through the mountains Ashville NC.
RRoller123
Post by RRoller123 »
Did that major ice storm a short while back cause much trouble? I am looking for Winter RV sites; planning a trip down the coast very soon, but I love the mountains too, and wonder what the climate is like there in the Winter? Is it RV-able all year round?
sigkadetm
Post by sigkadetm »
The worst time to go would be Feb. After that the danger of ice should start to diminish. It could be pretty bad driving. The storm did minimal damage so you are good to go in the mountains. The piers at Myrtle beach got severe damage.
RRoller123
Thanks for the info! It seems like we need to go at least as far south as Charleston to comfortably RV for the Winter. :?:
