1980 Fiat 2000
DesertFox
Your car is a: 1980 Fiat Spider Pininfarina
1980 Fiat 2000
Post by DesertFox »
I am new here. I inherited a 1980 Spider that has sat since 1990. I have a few questions. What is the tire size? It is rotted off. When I started the car it just clicked. What could that be? Thanks for any inquiries!
1980 Fiat 2000 Pinifarina
bobplyler
Patron 2022
Patron 2022
Re: 1980 Fiat 2000
Post by bobplyler »
26 years is a long time to sit. Is the engine seized? Take the spark plugs out, and see if you can turn the engine over with a socket on the front of the crankshaft.
1979 Fiat Spider (since new)
1999 Honda Shadow VLX 600
DesertFox
Re: 1980 Fiat 2000
Post by DesertFox »
Ok. Thanks for your reply. I will try that.
courtenay
Re: 1980 Fiat 2000
Post by courtenay »
What's the condition of the battery?
Bruce Shearer
'80 Spider Fi
'10 Volvo XC70
'06 GMC 1 Ton PU
vandor
Re: 1980 Fiat 2000
Post by vandor »
You will likely have to clean out the fuel system and replace any rubber hose. A new fuel tank may not be much more that what a professional cleaning will cost.
Is it carbureted or injected? If injected likely the injectors are stuck.
Original tire size is 165R13, but a common upgrade is 185/70R-13. If it has 14" wheels then the original size was 185/60-14.
Fiatlanta
Your car is a: 1979 Spider 124
Re: 1980 Fiat 2000
Post by Fiatlanta »
Pics!
DesertFox
Re: 1980 Fiat 2000
Post by DesertFox »
The battery is bad, and was under recall too. It is carburetated. How do you post pictures?
courtenay
Re: 1980 Fiat 2000
Post by courtenay »
Step one would be to put a new battery in it. Step 2 would be to drain the fuel tank and put new fuel in then give it a try. You might get lucky.
Bruce Shearer
'80 Spider Fi
'10 Volvo XC70
'06 GMC 1 Ton PU
RRoller123
Re: 1980 Fiat 2000
Post by RRoller123 »
DesertFox wrote:The battery is bad. It was under recall too. It is carburetated. How do you post pictures?
Here is a thread on how to post pictures directly to the forum:
http://www.fiatspider.com/f15/viewtopic ... 13&t=32169
And here is another picture-posting thread:
http://www.fiatspider.com/f15/viewtopic ... 12&t=23084
This short instruction covers how to resize pictures so that they don’t get cut off at the right side:
http://www.fiatspider.com/f15/viewtopic.php?f=3&t=30441
DesertFox
Re: 1980 Fiat 2000
Post by DesertFox »
Re: 1980 Fiat 2000
I would certainly lubricate all the cylinders with auto trans fluid before attempting to turn the engine
DesertFox
Re: 1980 Fiat 2000
Post by DesertFox »
So Cal Mark wrote:I would certainly lubricate all the cylinders with auto trans fluid before attempting to turn the engine
Ok.
Fiatlanta
Re: 1980 Fiat 2000
Post by Fiatlanta »
DesertFox wrote:
Fiatlanta wrote:Pics!
https://postimg.org/gallery/1kbopzaem/
Thanks!
Looks like a lot of work, but not impossible. Good luck!
DesertFox
Re: 1980 Fiat 2000
Post by DesertFox »
Thanks!
Thanks. I'll try to have it driving before I get my license.
DesertFox
Re: 1980 Fiat 2000
Post by DesertFox »
Where is power window switch
