Throttle posistion switch
sigkadetm
Your car is a: 1980 Fiat spider 2000
Post by sigkadetm »
Do you set the idle first then adjust the throttle position switch? Can't remember
RRoller123
Re: Throttle posistion switch
Post by RRoller123 »
Yes, keep the TPS loose so it is properly switched, then after setting things, rotate it so it just clicks when the throttle is actuated. It has been a while since I did this, but I seem to remember that the TPS can actually hold the throttle plate open and screw up the whole idle speed setting, so it should be done last. Just make sure it is fully loosened so it doesn't interfere with the idle setting process.
sigkadetm
Post by sigkadetm »
Thanks I appreciate the info.
