IDF Emusion Tubes High or Low Set
jandarah
Your car is a: 1977 124 Spider
Post by jandarah »
Hi,
I have older twin IDF40's on my 1756 Spider. It has the emulsion tubes low set at the top plates of the carbies. I notice plenty of photos of the newer models, with the top of the tubes very highly set above the top plate. Is there any particular reason for this? Does it help with air intake through the top of the screw head? If there is an advantage, can these be used on the early model Webers?
John in Oz
First Fiat: 1970 124 sedan 1970 - 1976
Then horse float towing vehicles up to present.
Current Fiat: 1977 124 Spider 1756cc with twin Weber 40 IDF's
1970 124BC coupe; 1756cc with twin Weber 40 IDF's, used for sprinting
