Switching Back to Points and Condenser - What's involved?
SeldomSeen
Your car is a: 2018 Fiat 124 Spider
Post by SeldomSeen »
The PO installed a solid state ignitiion in my '69 124 spider and my mechanic said that my particular engine (which he competently rebuilt) would run better with the original style ignition. I have never looked at what an electronic ignition system is composed of. What do I need to do to revert back to the older technology?
It's never too late to have a happy childhood - Tom Robbins
1972 Alfa Romeo GTV 2000
1966 MGB Roadster
2007 MINI Cooper S
2018 Fiat 124 Spider Classica
Re: Switching Back to Points and Condenser - What's involved?
your mechanic should come out of the dark ages. Your points-system will be about 1/4 as efficient as even a mediocre electronic system and will need attention every 6 months
Turbofiat124
Your car is a: 1980 Spider 2000 turbo
Post by Turbofiat124 »
I agree. If you want to keep a "stealth" appearance, I would go with a Petronix system. I'm pretty sure they make a system for this distributor.
I've converted all my points cars to electronic ignition and have no regrets. My Citroen 2CV is still running on points but that's only because I've only had it a a couple of months and have not gotten around to buying a system. The cheapest one I've found so far is $135.
klweimer
Post by klweimer »
Agreed. I love lots of old school technology, but ignition systems from the 30's are not one of them.
SeldomSeen
That's what I always believed. Besides, the thought of dropping that adjustment screw into the works gives me nightmares.
1966 MGB Roadster
2007 MINI Cooper S
jandarah
Your car is a: 1977 124 Spider
Post by jandarah »
Agreed re electronic. Both my 1756 Spider and my 77 competition BC coupe run 123ignition.nl units. Not cheap, but built like a battleship, easy to setup and settings can be internally changed. So far, both are working well.
John in Oz
First Fiat: 1970 124 sedan 1970 - 1976
Then horse float towing vehicles up to present.
Current Fiat: 1977 124 Spider 1756cc with twin Weber 40 IDF's
1970 124BC coupe; 1756cc with twin Weber 40 IDF's, used for sprinting
