Picture needed: Trunk keep-open bar install
nelsonj
Your car is a: 1972 Spider 124
Post by nelsonj »
Hi all,
At one time my trunk had a spring loaded bar mechanism that could be turned out to hold the trunk open. It was bent and never worked correctly, During my restoration I put on a different truck lid that didn't have the keep-it-open bar.
Can someone post a pictures of a working mechanism so I can see if I can acquire/fabricate and reinstall the device? Right now I keep a broomstick handle in the trunk and use it to keep the trunk open when needed.
Thanks.
Simi Valley, California
Spider 1800
Romans 10:9
kilrwail
Re: Picture needed: Trunk keep-open bar install
Post by kilrwail »
Here you go.
Peter Brownhill
1977 Porsche 911S - track car
2022 Ram 4 x 4 - hauler
nelsonj
Post by nelsonj »
Thank you very much! This gives me just what I needed.
Thanks again. :)
Spider 1800
Romans 10:9
daved
Your car is a: 1969 fiat 124 spider
Post by daved »
Was able to buy a used prop & spring a couple years ago.
cibon1
Your car is a: 124AS 1969 Fiat Spider
Post by cibon1 »
Nelson, here is a photograph of my mechanism. You should be able to get the spring and rod from someone like Mrfiat.com. Be careful when opening your trunk as it can hit the part behind the top if opened too far. Gregory
