Exhaust manifold heat shield missing on '81
- KevAndAndi
- Your car is a: 1981 Fiat Spider 2000
I understand the heat shield is affixed with studs screwed into the manifold. My manifold lacks any attachment points. So it must not be original to my '81, correct? If I were to acquire a shield for an '81, would there be any alternative way to attach it? Or is there an earlier shield that would work that is attached in a different way? Or should I leave well enough alone?
Kevin
1981 Spider 2000
1981 Spider 2000
- divace73
- Your car is a: 1980 Fiat 124 Spider Silver
Re: Exhaust manifold heat shield missing on '81
does your exhaust manifold have the O2 sensor installed?
Cheers David
see my >>You tube channel<<
- KevAndAndi
It does.divace73 wrote:does your exhaust manifold have the O2 sensor installed?
Kevin
1981 Spider 2000
1981 Spider 2000
