Brake line bubble trouble
- Nanonevol
Trying to replace the hard brake lines to the rear brakes. Tracked down the right 10 x 1.25 fittings but confused on the flare making. I remember hearing somewhere I need to make a bubble flare. Bought a tool at O'reillys which I was told would make these but now that I have it I see it makes a folded over flare which I fear will not seal inside my new soft brake lines and other fittings. How to make a bubble flare? Do I have the wrong tool. I also bought copper lines on O'reillys recommendation (won't rust) but recall reading about problems with copper as well.
1977 Fiat Spider
1985 Jaguar XJ6
1966 BSA Lightning
1985 Jaguar XJ6
1966 BSA Lightning
- Nanonevol
Re: Brake line bubble trouble
Wow! I never would have come up with that idea! Is that your own invention?
1977 Fiat Spider
1985 Jaguar XJ6
1966 BSA Lightning
1985 Jaguar XJ6
1966 BSA Lightning
- Nanonevol
The instructions on my tool show a two step process and it looks like you simply skipped the second step which folds the bubble in on itself. I'm not sure what the washers function is.
1977 Fiat Spider
1985 Jaguar XJ6
1966 BSA Lightning
1985 Jaguar XJ6
1966 BSA Lightning
I wouldn't use copper, the brake lines should be steel. Remember, the O'reilly guy sells parts because he can't make a living repairing cars
- Nanonevol
That's funny and I'm sure it's true. In fact a lot of auto parts guys I've seen don't know auto parts either. So why not for the copper? Is it too weak?
My problem of the moment is bleeding the system. All four calipers are rebuilt so I would expect a lot of air but the rears seem to bubble forever. My fear is that my "T" connection fittings on the rear axle are leaking air. Could this be the problem or should I just expect to have to bleed a lot of air?
1977 Fiat Spider
1985 Jaguar XJ6
1966 BSA Lightning
1985 Jaguar XJ6
1966 BSA Lightning
When i did it without the washer it did not fit that well. I am not sure if you are using the same tool? without the washer the bubble was flatter than the original and I was not happy with the fit. With the washer it is exactly the same profile as the original in the photos and seals completely
- Nanonevol
Yes, I have basically the same tool but couldn't quite get your results with or without the washer. I was a least able to make the fitting a bit convex but I think it's leaking at the "T" connection on the axle. I'm trying to bleed the rears but I think that leak is letting in air. Not sure what to try now. I may look for the adapters that Edelmans makes.
1977 Fiat Spider
1985 Jaguar XJ6
1966 BSA Lightning
1985 Jaguar XJ6
1966 BSA Lightning
besides copper being too soft, it's made for compression fittings
- Nanonevol
Crap! Damn those O'reillys guys!
1977 Fiat Spider
1985 Jaguar XJ6
1966 BSA Lightning
1985 Jaguar XJ6
1966 BSA Lightning
From what I remember when doing the flares. I would get an uneven neck crimp from the basic tool, the washer helps keep it square when shaping the bubble at the neck, so when you tighten it up it applies equal pressure all-round in the caliper (no leaking)
- Nanonevol
Thank you Drummond for all your help. I see what you mean about the washers. In fact I've viewed a lot of You-Tube videos on this and one persons tool had a side that was flat rather than concave so he could make the bubble flare without the washer.
Frankly I'm losing confidence in my ability to make a hard brake line joint that doesn't leak. I think I'll look around for a garage that can make the flares for me.
1977 Fiat Spider
1985 Jaguar XJ6
1966 BSA Lightning
1985 Jaguar XJ6
1966 BSA Lightning
I've never been cool enough to do reliable bubble flares either. What I've done instead is purchase small adapter fittings that you screw into all your brake components (calipers, master cylinder, etc) and they adapt everything to standard US brake lines. The fittings looks like so:
http://www.oreillyauto.com/site/c/detai ... &ppt=C0248
That way, you can screw up brake lines to your hearts content, and just keep going back to the parts store for more.
Kirk
Kirk
- Nanonevol
Another work-around might be to buy the line with bubble flare - but with the m10 x 1 fittings or whatever's available - and cut it, put on the correct m10 x 1.25 fittings and splice it back together.
1977 Fiat Spider
1985 Jaguar XJ6
1966 BSA Lightning
1985 Jaguar XJ6
1966 BSA Lightning
