are 1800 cam the same as 2000?
BammBamm
Your car is a: 1982 Pininfarina Spider
Post by BammBamm »
I trashed my 2000 cams but have a nice set of 1800. Will they work? Also how should I secure the cam box so I can unscrew the cam pulley bolt?
Bill Woodbury
Design Engineer
Zero Shock Seating
1982 Spider 2000
RRoller123
Re: are 1800 cam the same as 2000?
Post by RRoller123 »
A chain wrench applied around the pulley, protected by an old timing belt, will do the trick to get the cam pulley bolt off.
klweimer
Post by klweimer »
An impact wrench to go along with the chain wrench will really make it easy.
Kirk
carl
Post by carl »
1800 and 2L cams are totally interchangeable.
131
Post by 131 »
carl wrote:1800 and 2L cams are totally interchangeable.
Depends on if you require the drive gear for a cambox mounted distributor.
Mick.
1800 cams have a drive gear on the exhaust, just as the 2L cams do
BammBamm
Post by BammBamm »
Bill Woodbury
Design Engineer
Zero Shock Seating
1982 Spider 2000
