Not sure if this is a problem or not. I have not seen this engine run well yet. I have found a bunch of items that could lead to a poor running engine. I am not sure on this piece missing.
No diaphragm, or push rod.
32ADFA Choke unloader - Missing
- Your car is a: 1978 Spider 124
Re: 32ADFA Choke unloader - Missing
It is a serious Problem.
Without these pieces your engine would never run well
http://images.google.de/imgres?imgurl=h ... 3&biw=1536
Rubbish, it just means it doesn't have cold start enrichment and fast idle, not the end of the world.frischling wrote:It is a serious Problem.
Mick.
Rubbish, if you live in Australia.
A choke is very important for colder climates.
And its much easier to handle the car as daily driver.....
Just my 2 Cents.....
- Nanonevol
Isn't the missing diaphragm (readily available) the accelerator pump? Important piece.
1977 Fiat Spider
1985 Jaguar XJ6
1966 BSA Lightning
1985 Jaguar XJ6
1966 BSA Lightning
- Your car is a: 1970 128
Thanks guys. I will find, at minimum, the diaphragm that fits, but will look to replace all the bits.
The rebuild kit I am using had a diaphragm that looks like it should have gone here. But, it is smaller version around 2/3 of the size of what is needed. All of the other gaskets/parts fit perfect.
Dan
Dan
- johndemar
Dan,
I've got the original 32ADFA off my car as well as most of another one.
You're welcome to them if you want. I just have to remember where I put them.
I'm out of town this weekend, but will look when I get back.
76 Fiat 124 Spider
One owner since July 20, 1976
Amadio Motor, Jeannette, PA
We do have winter. I have no cold start enrichment on my IDFs, in winter I have to start it on the accelerator pumps, and it runs like a dog until it gets up to temperature, after that it's quite civilised, and I use it as a daily driver.frischling wrote:Rubbish, if you live in Australia.
Mick.
