32 ADFA off eBay...
Fiatlanta
Your car is a: 1979 Spider 124
32 ADFA off eBay...
Post by Fiatlanta »
http://m.ebay.com/itm/ORIGINAL-WEBER-RE ... ING_ACTIVE
Wanting to upgrade carb and intake manifold on my 1979...this should do the trick, huh?
kmoses
Re: 32 ADFA off eBay...
Post by kmoses »
This would give you more bang for the buck: EMPI 32/36 DFEV Carburetor at Allison's Automotive $255.
Fiatlanta
Post by Fiatlanta »
Would I still need to get the 1800 single plane manifold?
Odoyle
Post by Odoyle »
I believe you can use the stock manifold with the 32/36, that is what my 79 has, but if you don't need to comply to emissions, get the single plane.
kmoses
Post by kmoses »
Yes, get a single plane intake manifold.
Fiatlanta
Post by Fiatlanta »
Emissions is not an issue. Looks like this should do the trick. Thanks!
Fiatlanta
Post by Fiatlanta »
Can I use stock air cleaner with 32/36? Really want to get rid of the oval cleaner I have on there now. Also have a rectangle cleaner..."lunchbox" style, I guess? Would prefer to go back to stock it possible.
bobplyler
Patron 2022
Patron 2022
Post by bobplyler »
The top of the 32/36 is different from stock. The stock air cleaner can be made to work, but it takes a lot of modification. Better to use the lunchbox.
1979 Fiat Spider (since new)
1999 Honda Shadow VLX 600
Exit98
Post by Exit98 »
bobplyler wrote:The top of the 32/36 is different from stock. The stock air cleaner can be made to work, but it takes a lot of modification. Better to use the lunchbox.
But the 32 ADFA & the 34 ADFA will use the stock air cleaner. No mods necessary.
My car had a lunch box when I got it. I upgraded to the 34 and put an original air filter back on. I like it that way. For me the lunch box allowed to much air sucking noise.
The 34 ADFA's are getting hard to find but they are sweet.
chrisg
Your car is a: 1971 FIAT
Post by chrisg »
but good induction noise is so nicely Italian...
Chris Granju
Knoxville, TN
'71 FIAT 124BS (pretty), '72 FIAT 124BC,'76 FIAT 128 Wagon(ratbeast), '85 Bertone X 1/9, '70 124BC (project), 79 X1/9 (hot rod in rehab), '73 124BS (2L, mean), '74 124 Special TC, '73 124CS, '73 124 Familiare
