Mark,
I would love to have one of your headers, its just the wallet is a whee bit empty at the moment. Unless you want to supply a slight discount...
I am located in Jacksonville, FL; if anyone wants to come by and take a look drop me a line, but I may put you to work.
The biggest issue with the intake manifold was space and I took the if it ain't broke don't fix it approach to it. It really is quite interesting to try and sandwich the fuel rail and fittings in there with the amount of space available. The angle is little harsh for flow on the PBS manifold but I couldn't get anything better by custom making anything myself. In addition, the head has not been fully ported nor have I installed larger valves, to as of right the the intake manifold/throttle bodies far out flow the head in terms of potential horsepower.
Once I get prove of concept, a good tune, and more money, I will fully port the head and maybe put large valves in. The deal is though that this is a fast road car and the modification was more for fun/just to see if I could do it then for massive gains in horsepower. I don't want to more the powerband TOO far north.
The fuel rail originally came 18 inches long put I had it cut down by my machinist to 13 inches to fit in the engine bay. Compression fitting hardline AN adaptors link the stock FIAT 5/16 fuel hardlines to the fuel rail via Earls Superstock hose.
I am slightly worried about the injectors being too big for a smooth idle (MS likes the idle pulsewidth to be about 1.6ms; I will likely be skirting just around there.) To help counteract this I am going to be upgrading to the MSII chip and ExtraII code which has higher resolution and better acceleration tuning algorithms. But then again, I won't know the fuel requirements exactly until I get to tuning. The 'vacuum log' you see if to balance out the manifold pressure pulsations that the ECU uses to tune the engine. Essentially, this creates an artificial plenum to dampen the pulses, though making it too large can introduce lag in the ECU's response. (I have since painted it black and placed it into the spot where the charcoal canister used to be.
The next thing I am toying about doing is making a fiberglass airbox...but I am getting ahead of myself.
