A few weeks ago I took the front bumper off. Looks great and got rid of an ugly 40 pounds (estimated)! Being that I am planning a move in the spring, I want to keep the car in a rolling status. Therefore, I'm not going to (permanently) remove the wheels or whatnot. Fortunately, that still leaves a lot of other areas I can work. I already know I'll be replacing the inner, middle, and outer rocker panels on both sides in the future. I also know I have some cancer on the right door skin. I also know I have to figure out something for the hood hinge pins as they not welded on properly, and the metal surrounding it is starting to tear apart. I'll have to get a new hinge for the hood, and repair/beef up the surrounding metal. I will also need to properly repair the outer wheel wells (flairs) and the rear panel under the tail lights. Any other corrosion will be dealt with as I find it. I'll be going over this vehicle a section at a time until I'm able to get it permently moved into the shop that WILL be at my next house (My wife knows that's a requirement for us for our next house).
Tonight I pulled the rear "seat" and was surprised to see no corrosion. There was a spot that I thought was corrosion, but turns out it appears to be just a v-shaped cut in the metal. I'll go underneath later on and verify there is no other corrosion in that area. If not, I'll pound it back into position, stop-drill the ends to prevent possible cracking, and weld it back up. Here it is.
I also removed the passenger seat, the nasty carpet on that side, and the insulation. After most of it is up, I found there is this nasty black (rubber like) material that is about 1/8" to 1/4" thick. I've managed to scrap up about half of it behind the cross member.
Does anyone know a good way to get this crap up? As soon as I find my heat gun, I'll add some heat to it in hopes of making it easier to scrap up.
While digging around, I did find some corrosion around the rear of the right passenger seat rail. The rails appear to be in good shape, so does the cross member. Although, the cross member isn't secured very well. The outboard side is welded with just a few spot welds. After repairing the floor pan, I will be welding that cross member on better so that there is little to no chance of it breaking free. The original color (white) can also be seen in this photo. I'm strongly considering going with some sort of a white color when I'm done.
