A peek under the hood of my new Fiat w/pics
Fiatlanta
Your car is a: 1979 Spider 124
Post by Fiatlanta »
Snapped a few shots last night under the hood, thought I'd share and see if I could get some input.
First up, the previous owner had the smog equipment yanked, which is a nice bonus for me. I replaced the vacuum tubing and screw he had in place with these caps. Seems like there should be more than that, though...am I missing an exposed opening somewhere?
Some more holes that look like they should be plugged...one of them simply has a screw in it, the rest are open. Sorry for poor quality, was hard to get a good shot.
Heat shield has a bolt head broken off...not sure if it's worth it to try and replace or not.
Overall, doesn't look too bad, unless someone sees something that I don't. Little bit of oil accumulated around spark plugs and under carb...going to wash it all out and see what that's all about. Going to go ahead and replace valve cover gaskets, as well, as previous owner indicated it needed to be done but didn't get around to it.
Fiatlanta
Re: A peek under the hood of my new Fiat w/pics
Post by Fiatlanta »
Not sure what's going on with the pics...will have to track it down later when I'm not at work.
Here's a link to all the pics in the meantime, fwiw
https://imgur.com/a/Z1gUb
zachmac
Post by zachmac »
Pretty sure all of those multicolored two eared thingies nearest the firewall are electrical connections for sensors, not ports. Best to either let em be or better yet if you want to clean up remove all the sensors and replace them with the proper size metric taper plugs. You can get those at BelMetric.
Are they part of the intake manifold or a separate piece? Not real familiar with the 79 but I know it had LOTS of pollution sensors.
Jeff Klein, Aiken, SC
1989 Spider, sold
2008 Mercedes SL65
2008 S600 Mercedes V12
AriK
Post by AriK »
zachmac wrote:Pretty sure all of those multicolored two eared thingies nearest the firewall are electrical connections for sensors, not ports. Best to either let em be or better yet if you want to clean up remove all the sensors and replace them with the proper size metric taper plugs. You can get those at BelMetric.
They are in fact vacuum ports. The ton of spaghetti hoses have long been tossed.
silvadw
Your car is a: 1979 Spider CS2 weber 34adf
Post by silvadw »
I agree with Arik, They are vacuum ports for the '79 twin plane intake.
I suggest change the intake to a single plane ('78 or earlier) and put on a suitable carb with a mechanical secondary. The original 28/32 ADHA is not good.
I bought a new 34ADF and put it on a '78 single plane intake. Car already had 4-2-1 exhaust. Car runs like it should. Stock cams and pistons.
various KTMs and V8's
RR Sport
'79 Spider 2000
bluespider262
Post by bluespider262 »
I have any original parts you may need to put that back to stock. I also did the 1.8l intake and holley 5200 from a 72 2.0l Capri and don't look back. Runs very strong vs stock.
Fiatlanta
Post by Fiatlanta »
So in the meantime, while I'm still kinda learning where everything is and not ready to start any serious tinkering...what shall I do with those openings?
For what it's worth, I have both a K&N air filter and what appears to be the original saucer style....so basically, I have all three of the top three pictures here as options:
http://www.kendickson.com/car/idf/singles.html
silvadw
Post by silvadw »
Carb looks a bit leaky, could do with a clean.
If it runs ok then leave it until you can get a better intake/carb setup. If it has issues, i can probably find my pics i took on how it should all be connected and post them. My setup was worked as stock with all the pollution stuff connected, i.e. lethargic. Runs better now, see my post above.
RR Sport
'79 Spider 2000
silvadw
Post by silvadw »
oh yeah, and i still use the original air cleaner setup, with new filter or course. This is the top picture in your posted link
RR Sport
'79 Spider 2000
you don't need to do anything with the thermal vacuum switches
Fiatlanta
Post by Fiatlanta »
silvadw wrote:Carb looks a bit leaky, could do with a clean.
Runs pretty good now. Misses occasionally, but overall runs fine. I wouldn't mind taking a look at the pics, though, if it's not too much trouble.
Going to try and get it cleaned up a bit this weekend or next week after kids start back at school and I have a little more time.
Thanks!
Fiatlanta
Post by Fiatlanta »
So Cal Mark wrote:you don't need to do anything with the thermal vacuum switches
That's all those multicolored holes in the back?
jagonza
Your car is a: 1977 Fiat 124
Post by jagonza »
I am in West Cobb, let me know if you want to go for a tandem cruise. are you going to caffeine and octane next Sunday ??
1977 Fiat 124 - Frankenstein engine
1999 VW Cabrio - Stock
1988 Fiero GT
And a couple of Daily Drivers
Fiatlanta
Post by Fiatlanta »
jagonza wrote:I am in West Cobb, let me know if you want to go for a tandem cruise. are you going to caffeine and octane next Sunday ??
I was not aware of any such event. Unfortunately, I work Sunday.
And yeah, I'll hit you up sometime seeing as how we are pretty close!
