Poly Bushings
- red107
- Contact:
Poly Bushings
Anybody ever seen a complete poly bushing kit for the rear trailing arms 78-85?
1981 Fiat Spider 2000
2015 Ram Eco Diesel 4X4 Laramie
2018 Jeep Wrangler JLU
- Your car is a: 1979 Spider
Re: Poly Bushings
Jeep tj adjustable control arm parts abound. You can make your own arms and run rubber poly or cartridge joints.
You probably wouldn't need to modify the spider itself to adapt these. 10mm bolts and 2" width iirc.
- red107
- Contact:
Re: Poly Bushings
Interesting, I thought about modifying the stock control arms. Similar to the TJ but with fix joint instead of hiem joint.
