Replacing the differential
Greetings, We live in New Zealand we have a 1981 2000 Spider auto that has a whine in the diff. I have checked the oil and it has plenty. I was going to pull the diff apart, thinking it may be the pinion bearing, but then I have found a dismantler who is dismantling a 1983 Fiat 131 Mirafiori CL. Does anyone know if the diff from the 131 will be interchangeable with the 131 Spider diff? Cheers Noel
Re: Replacing the differential
the 131 used drum brakes rather than disc, and the ratios are different.
