I've been driving my car a ton with all the nice weather and no rain, and haven't had any issues in a while. Today while I was in the garage I noticed a weird puddle next to the passenger side rear tire. The fluid was brown/reddish. The only place I see any fluid is on the bracket where the sway bar secures. You can see where its wet there above the puddle in the pic. None on the axle or anywhere else. I can't understand where it could be coming out of or what it would be, but suspension components are probably my weakest area so I hoped it would be obvious to someone on here.
It doesn't seem to be a brake fluid leak, because I have a firm brake pedal still, and I would expect even a small leak to ruin the feel. Also the level in the reservoir looks fine.
The only thing I can think of that is back there to leak is the rear differential. However, I do not understand how the fluid could get in that location.
Any thoughts?
