Transmission removal?Gearshift
RaneeHobbs
Post by RaneeHobbs »
I am getting ready to remove my Fiats transmission. The manual says to remove the top half of the gearshift. I have tried my to pull it off but its a no go. Am I doing something wrong? Ranee
76was124
Patron 2019
Patron 2019
Re: Transmission removal?Gearshift
Post by 76was124 »
There are a couple threads if you search...here's one.
http://www.fiatspider.com/f15/viewtopic ... al#p202518
Current 81 Spider 2000
Previous 76 Spider
vandor
Post by vandor »
I found that when removingthe transmisison the entire shifter has to be removed. Undo the three 10mm bolts at the bottom and once the cover is rmeoved undo the 13mm nut in the center. The pivot assembly will fall apart and down and the shifter can be pulled up with a little wiggling.
