What spark plug should I use?
gtlotus
Your car is a: 1975 spider
Post by gtlotus »
I have a '75 Spider with an 1800 (std), high compression(10:1), street cams, big valves, duel 40 IDF, headers and 2-1/4 exhaust with a MSD. What would be the best plug to use?
Thanks,
Gene
131
Re: What spark plug should I use?
Post by 131 »
I've got basically the same bits in a 2 litre, I've always run NGK BP6ES.
Mick.
gtlotus
Post by gtlotus »
Thanks!
