carburetor selection
piperstan10
Your car is a: spider 1973
Post by piperstan10 »
I have a 73 124 fiat spider with a 1979 2,000 cc carbureted engine. The ignition is electronic (not mechanical points) with vacuum advance. What is the best carburetor for good performance? And, are these carburetors available? I have no smog requirements.
Currently the engine hesitates (almost stalls) when accelerating from idle/startup.
Any suggestions?
Stan
vandor
Re: carburetor selection
Post by vandor »
You need to check which intake manifold you have, because the stock 2000 intake manifold is very restrictive and will limit any gains from a new carb. The least expensive carb would be a Weber or EMPI 32/36DFEV, they offer good performance and are easy to adapt.
What carb is on there now?
piperstan10
I have a weber 34adf which I just removed and am in the process of cleaning. The carb is probably 15 years old - don't remember when I purchased? The manifold I believe is an earlier version perhaps 1973 which I (hand) ported and polished. the car has been running ok - but recently (not used very much) started acting up especially at low rpm's. I have cleaned the carburetor jets/and channels using carb cleaner. Looking for a procedure (and specs for adjusting the float?) ---- looked like the carburetor bowl was low when I removed - about 1" of fuel in bottom. Electric fuel pump.
Too bad IAP is no longer around they had a great refefence source.
johndemar
Post by johndemar »
I'm happy with the 34adf I have on mine, but the only reference I have is the 32 I replaced.
Maybe it is just a matter of adjusting and cleaning.
Did it just recently start having issues on an otherwise good running engine?
76 Fiat 124 Spider
One owner since July 20, 1976
Amadio Motor, Jeannette, PA
piperstan10
I have been happy up till now. Do you have the manual or do you know the float settings? BTW in going back through my memory, I recall that I used an intake manual from a 76 -124 engine, that was recommended. So I ported this manifold to my block.
I found on line a manual for a 32 ADFA which has 6mm and 14mm for the float?
Stan
vandor
Post by vandor »
The specs for the 32ADFA should be the same.
piperstan10
Update: Thoroughly cleaned carburetor.
Attempted to adjust float level but the float measurements (fuel level SPEC for 32 ADF - 6 to7 mm- currently set at about 4 mm) did not make sense in that the bowl fuel level would have been too low - Perhaps the float valve is a different model than original (or shutting off late) - which does not make sense since it has not been changed since new? The current fuel level is ~ 1" w/o float and covers all ports. This is roughly less that 1/2 the total bowl capacity -
End result is that the cleaning corrected the problems with low speed hesitation.
Thanks to all for the assistance!
I need read up to understand more about level of fuel in carburetor bowl!
Stan
131
Post by 131 »
6mm including gasket. The float bowl doesn't need to be full, if it is, there's something wrong.
Mick.
