How to tell if catalytic converter bad?
- rjkoop
Any idea how to tell if the catalytic converter on my '81 is bad? The rest of the exhaust from that point to the muffler was replaced because it was rusted out. I fixed a minor leak in the CAT but didn't want to replace it. I also cleaned it out (youtube'd a few techniques) but just want to ensure it's not causing any flow issues. Is there a way to check this?
I don't have a test pipe but if the CAT is bad I may get one from AR and replace.
Richard
1981 Fiat Spider
Ottawa, Canada
1981 Fiat Spider
Ottawa, Canada
Re: How to tell if catalytic converter bad?
Usually they get plugged up. You'd notice an abnormal lowered performance. I've never seen it on a Spider but I've had a car where the exhaust manifold glowed red at night. That couldn't do no favors for the valves.
Or just buy a new one. I got this one for $160 on ebay.
http://www.ebay.com/itm/121293580490?_t ... EBIDX%3AIT
Kirk
Kirk
use an infrared temp gun to check the inlet and outlet temperatures. A good working cat will be 100 degrees hotter at the outlet
- rjkoop
That looks really slick. Thanks for the link.klweimer wrote:Or just buy a new one. I got this one for $160 on ebay.
Kirk
Richard
1981 Fiat Spider
Ottawa, Canada
1981 Fiat Spider
Ottawa, Canada
- rjkoop
In Canada those cost about $99. Maybe I'll see if I can borrow one.So Cal Mark wrote:use an infrared temp gun to check the inlet and outlet temperatures. A good working cat will be 100 degrees hotter at the outlet
Richard
1981 Fiat Spider
Ottawa, Canada
1981 Fiat Spider
Ottawa, Canada
30 bucks works for me, they are having a big Memorial Day Weekend sale too.
I got one for about $30 at Canadian Tire.rjkoop wrote:In Canada those cost about $99. Maybe I'll see if I can borrow one.So Cal Mark wrote:use an infrared temp gun to check the inlet and outlet temperatures. A good working cat will be 100 degrees hotter at the outlet
1974 Honda CB350F
1981 Fiat Spider 2000
$0.00 if you just remove it as it is not required for emissions testing etc
$19.99 at Princess Auto
http://www.princessauto.com/en/detail/i ... -p8496622e
Out of stock item at this time.4uall wrote:$0.00 if you just remove it as it is not required for emissions testing etc![]()
$19.99 at Princess Auto![]()
Range is a little low on that one for checking a cat since fully lit they can be over 500 degrees F to a max of 1,200 F before they are considered overheated while that thermometer maxes out at 485 F.4uall wrote:this is http://www.princessauto.com/en/detail/c ... -p8568750e
Here is what Walker Exhaust has in its Converter FAQ:
" Keep in mind that the converter's rear weld ring temperature is directly related to the amount of work the converter is performing. Therefore, elevated temperatures may indicate an emissions issue.
If the rear weld ring is significantly cooler than the front, the converter may not be lighting off. This may indicate the converter has failed, or that the exhaust mixture is not correct - the symptom of an underlying emissions issue.
Typically, converter temperatures will not exceed 1200º F on a properly running engine. Periodic operation above 1600º F can negatively affect the precious metals coating on the substrate, reducing its efficiency. Excessive temperatures can reduce the converter's durability, or - if high enough - destroy the converter's matting or substrate.
Damaged matting and melted substrates typically occur at temperatures exceeding 1700º F. It is possible to test for a cracked substrate or damaged matting by tapping on the converter housing. Using a rubber mallet, "thump" the shell, listening for loose components.
A bronze / blue rainbow discoloration of the shell typically indicates elevated temperatures. If the converter is removed, look through the substrate to observe whether the small passageways are melted or collapsed. The substrate may actually appear normal at either end, since the substrate melts internally."
- rjkoop
Yep. Just a little worried and not going stock and the exhaust noise being too loud. Although right now there is a minor leak at the catalytic converter (I fixed with muffler repair goo but it's starting to go again) and it's already a little noisy. Just trying to decide between a new CAT or the test pipe. I like the 'bolt in' type exhaust and would rather not get a muffler shop to weld in a new pipe. I like the idea that I can remove the exhaust myself.4uall wrote:$0.00 if you just remove it as it is not required for emissions testing etc![]()
Once again with what I've learned on this Fiat I was able to get the confidence to replace the exhaust on the kids beater 2008 Sentra (1/4 million kms!) myself for $300 when the muffler shop wanted to charge $1000+.
Richard
1981 Fiat Spider
Ottawa, Canada
1981 Fiat Spider
Ottawa, Canada
- Nanonevol
That's excelllent! It is a great feeling when you can fix something yourself! I went with the test pipe, muffler and Ansa in the rear was already there on my carbed '77 and it's really not loud at all.
1977 Fiat Spider
1985 Jaguar XJ6
1966 BSA Lightning
1985 Jaguar XJ6
1966 BSA Lightning
