I'm wondering if someone knows of a grease that actually will last for use with polyureyhane bushings.. Everything I've used lasts a short while.. Then I have to take the joints apart and grease them again.. Very irritating!
Appreciate the help in advance.
Cheers!
Rob
Grease that actually lasts for poly bushings
- v6spider
http://www.v6spider.com
Re: Grease that actually lasts for poly bushings
The last set I ordered came with blue molybednium grease which lasted for many years on my 10 ton F53.
- v6spider
Is that the Marine based stuff? Think I have some of that. I'll have to give that a go.. It's not petroleum based is it? Not supposed to use that on polyurethane bushings. Apparently it breaks down the poly material in the bushing.
Cheers!
Rob
Cheers!
Rob
I just double checked with IPD Racing and its Aqualube polyurethane bushing grease specifically that they send out with their kits.v6spider wrote:Is that the Marine based stuff? Think I have some of that. I'll have to give that a go.. It's not petroleum based is it? Not supposed to use that on polyurethane bushings. Apparently it breaks down the poly material in the bushing.
Cheers!
Rob
http://www.ipdusa.com/products/7399/100 ... bar-grease
