Pushing Later Style Bumpers Closer to Body
- Your car is a: 1981 Fiat 2000
1981.2000. Is it possible, since the bumpers are on shocks, to somehow push the bumpers closer to the body? Can you remove the shock and slide it closer?
- rjkoop
Re: Pushing Later Style Bumpers Closer to Body
I did and love the look.Nitrate wrote:1981.2000. Is it possible, since the bumpers are on shocks, to somehow push the bumpers closer to the body? Can you remove the shock and slide it closer?
http://www.fiatspider.com/f15/viewtopic ... 30&t=32191
Richard
1981 Fiat Spider
Ottawa, Canada
1981 Fiat Spider
Ottawa, Canada
My rear bumper was pushed in. I wrapped a 250 lb climbing rope around it and my tractor to pop it out. I like the look better personally as pushed in there's alot going on with too much shadow hiding the lines of the car. 1,000 foot view perhaps they look better pushed in. To each their own, YMMV. IMO if you're willing to push them in and mitigate any safety they offer you may as well go bumperless. That's a huge visual improvement over the tube bumpers.
- Your car is a: 1981 2000 Spider
Yo Nitrate,
It's simple and looks great! Drill a 1/8 to 3/16 hole in the bumper shocks, letting the gas escape. Then, with some gentle force on both sides, push the bumper in so as to re-position it evenly close to the body. I left a small space so the rubber ends don't rub against the body. Once positioned, use the hole in the outer tube as a pilot hole to drill the inter tube again. Then run a screw to secure the fit.
Dave.
Dave.
Frog2Spider
'81 - 2000 Spider
Frog2Spider
'81 - 2000 Spider
Dave, Thanks for detailing the whole procedure. Appreciate that. RB
- Your car is a: 82 Spider 2000 + 76 128 Sedan
IIRC, they are oil filled, not gas. So, use a catch basin. YMWV.
Bill Barker
Madison, Wisconsin
1982 Spider 2000
1976 128 Sedan
Madison, Wisconsin
1982 Spider 2000
1976 128 Sedan
Maybe the 'gas' was only O2, but I suspect it was heavier. It sprayed oil for at least 10-15 seconds, before finally just dripping. Wear safety glasses!
Dave
Dave
Frog2Spider
'81 - 2000 Spider
Frog2Spider
'81 - 2000 Spider
Let's see how fast we can shut down this poser.
