Insulation
Insulation
Hello my Fiat friends. Decided to work on the little fiat. Well I couldn't stand the smell inside my car and started first with taking out the floor mats. Then I noticed that the insulation was completely wet. So the person that I am, I pulled all that insulation out of it!! Now my question is, where do I purchase insulation and what is the best to buy?
Re: Insulation
I have Hushmat in stock along with the foam layer to go under the carpet
Re: Insulation
Mark, let me ask a question... where did all this moisture come from and how to keep it out?
Re: Insulation
Does it smell like engine coolant? If so, it is likely from a leaky heater box/valve/pipes, etc. under the passenger side dash. It can be bypassed in the engine compartment, you will see two hoses going through the firewall there, side by side above the exhaust manifold. Many folks leave the heater permanently bypassed, which says a lot about the ease of the repair....
Re: Insulation
