I removed my exhaust manifold and discovered this:
[img][URL=http://s751.photobucket.com/user/ralphc ... w.jpg.html][IMG]
The cylinder head that receives the stud is distorted/worn and does not hold the stud securely. I plan on using J B Weld to "weld" the stud into the cylinder head. What do Y'all think about this proposed fix?
Exhaust Manifold - Stud Wobble
- 124JOE
Re: Exhaust Manifold - Stud Wobble
pls enter the whole code
- aj81spider
I'm no expert, but when I screwed up the stud hole on my head I took it to a machine shop and had them weld it over and tap a new hole. That has the disadvantage that they had my head for about a month.
To post your picture you need to click on the "share" button, then copy the "direct" link between the image tags.
A.J.
2006 Corvette
2006 Corvette
Thanks A J. Is that the image I was trying to post? Anyway, my cylinder head looks just like that photo. J B Weld's FAQ does not recommend using their product on a manifold but I think the temp on the cylinder head would probably not exceed 500 degrees Fahrenheit. It has been like that for some time without causing any significant problem. I do seem to have a very small oil leak from stud area. it is the last one (the one closest to the firewall). I've posted many photos to this forum. I'll have to review the procedure again. I use photobucket and their interface has changed a bit. Feeble excuse, eh?
- aj81spider
Hi Ralph,
That was your picture from Photobucket. I just followed the link in your earlier post.
A.J.
2006 Corvette
2006 Corvette
Would a heli-coil work and then install the stud with some thread sealant?
- azruss
That's what i would do.Would a heli-coil work and then install the stud with some thread sealant?
I was going to google "helicoil" but then thought I would give everyone a good laugh.....what the hell is a helicoil?
- lglade
A helicoil is essentially a bushing with threads on the outside and inside surfaces allowing you to step down a hole to accept a smaller bolt. I believe it's made from a coil of wire, hence the name.
Lloyd Glade- Mukilteo, WA
1962 Fiat 500D - wife's car
2015 Subaru Outback
2017 Ford Focus RS
2015 Subaru Outback
2017 Ford Focus RS
- 124JOE
yes its a square wire.so it has threads
