Synthetic Oil
jandarah
Your car is a: 1977 124 Spider
Synthetic Oil
Post by jandarah »
Hi, anyone using fully synthetic oil and, if so, what grade?
John in Oz
First Fiat: 1970 124 sedan 1970 - 1976
Then horse float towing vehicles up to present.
Current Fiat: 1977 124 Spider 1756cc with twin Weber 40 IDF's
1970 124BC coupe; 1756cc with twin Weber 40 IDF's, used for sprinting
vandor
Re: Synthetic Oil
Post by vandor »
Do not put it in an old engine or it will develop oil leaks.
jandarah
Re: Synthetic Oil
Post by jandarah »
Ok, I use full mineral oil anyway, from an Australian supplier/manufacturer. Just thought I would check.
John in Oz
4uall
Re: Synthetic Oil
Post by 4uall »
here is an interesting video about oils :wink:
https://www.youtube.com/watch?v=Se8-W7rK0H4
azruss
Re: Synthetic Oil
Post by azruss »
I use full synthetic in hot, hot Arizona. The motor has all new seals and it still leaks a few drops on the garage floor. I can live with that. To me, a fiat motor is like a detroit diesel. If its not leaking, it means you are out of oil. :mrgreen:
4uall
Re: Synthetic Oil
Post by 4uall »
phaetn
Your car is a: 1974 Fiat Spider 1800
Re: Synthetic Oil
Post by phaetn »
Not only can switching to synthetic develop leaks, in my case it even caused a seal to fail on a vintage bike.
I dunno why, for some dumb reason, I put synthetic in my '72 CL350. Next ride (a commute to work) it blew the clutch seal and oil literally just poured out from the base of the engine. I think the less viscous oil made its way through gaps more easily and I was lucky to not have had it happened so that I rode over it with my rear tire and took a spill.
I nursed it down a short hill to work, trying to let the engine turn over as little as possible, then had to put it in a friend's pickup to get it home. Ugh.
Damn I miss that bike:
And here was my '78 Vespa Super 150 scooter that I had tricked out (carb, electronic ignition, ported head, custom free-flow exhaust) before I sold it for the bike above:
Happily I now nurse my vehicle modification habit with the Spider, but it's all the same -- aftermarket more supportive seats, swapping suspension components, jetting carbs, fiddling with ignition timing, free-flowing exhausts, keeping an eye on blow-by of piston rings, torquing this and that, and always, always having an ear out for a change in tune or any funny noise. :)
Here's my latest project for the 124:
Until I get my valves seals done I think the Fiat burns more oil than the two-stroke Vespa ever did. :)
Anyhow, yes -- stick with dinosaur oil. I told you how I know even though you didn't ask. ;)
Cheers,
phaetn
1974 CS1
32/36 DFEV; CompuTronix ign.
9.8:1 c/r; 40/80 intake cam w/ Isky springs
Vicks' SS header & adj. cam pulleys
A/R's progressive coils, Koni Yellow dampers
205/50-15s on CD-66 style rims
Momo wheel, Corbeau seats w/ 5 pt belt
pics and HD vids
zachmac
Re: Synthetic Oil
Post by zachmac »
Yeah, one of the main reasons synthetic is so slick is smaller molecules. So, little leaks become bigger leaks. :D
Jeff Klein, Aiken, SC
1989 Spider, sold
2008 Mercedes SL65
2008 S600 Mercedes V12
