I have ordered some copper nuts to go on the header and I bought the transmission/ downpipe exhaust mount but I can't figure out how it mounts. It's not in the manuals or exploded diagram showing where it attachs. COuld someone give me a description or a pic of it mounted?
to be clear -this mount
http://www.ebay.com/itm/Fiat-124-Spider ... 1688821918
82 FI exhaust header keeps coming loose
- Your car is a: 1982 Pininfarina Spider
Bill Woodbury
Design Engineer
Zero Shock Seating
1982 Spider 2000
Design Engineer
Zero Shock Seating
1982 Spider 2000
Re: 82 FI exhaust header keeps coming loose
I think this is what you are looking at? Mounts between the transmission and the exhaust
- 124JOE
are you using lock washers under the nuts?
Thanks for the pic. That helps a bunch. I am using lock washing but they loose thier temper. Between the bracket and new nuts it should be ok.
Bill Woodbury
Design Engineer
Zero Shock Seating
1982 Spider 2000
Design Engineer
Zero Shock Seating
1982 Spider 2000
