I knew it was bad but not this bad. My upper actually separated right in front of me after I had worked the knuckle left and right a few times while disassembling the front end. I didn't have a jack under the lower arm because I "wasn't that far yet."
Thank goodness most of the tension in the spring was already released - I had just gotten done removing the shock from underneath not five minutes before which seems to take most of the tension off.
Be safe out there!
