Cam sprocket Diameter?
Can anyone tell me what the Outside diameter of the Cam sprocket is on a Spider 2000? Not the belt guide, but the sprocket teeth themselves. I believe this is a common size on all engines. I need to fit a Missing tooth wheel for a Megasquirt EFI setup so I teed this dimension. Thanks in advance.
