To my dismay I discovered that the passenger side frame rail is massively cracked and corroded on both sides of the crossmember. I somehow completely missed this when I bought the car, doing a driveway inspection on a chilly October evening in fading daylight. I am still kicking myself. However, considering the engine needs work, the engine mounts need replacing and I am sure to need to do front end work anyway, I might as well pull the engine out and take care of this. I found that VAS sells replacement frame rail sections, so it cannot be TOO uncommon an occurance.
Has anyone here done this job or had it done? I was OK with doing the mechanical work myself, but as far as the frame cutting and welding I would not attempt it myself. At the moment it seems kind of daunting. How specialized is this kind of work? I am not so sure the average body shop is set up to do this kind of work. If the measuring is not spot on the car will be screwed ever after. Help....
