Cheers!
Rob
Dead simple.. Just remember glass doesn't bend. I learned the hard way and broke the first one.. Hot tip, use grease and grease up the rubber seal before you attempt to slide the glass and rubber into the frame. It made a huge difference and you can wipe off the excess after its installed.. I used clear silicone grease... the glass was cheap too.. $150124JOE wrote:thats great Rob was it hard to do?
Thanks! Yeah I dreamt up the idea over 15 years ago! Quickly built one car as a test bed and then mothballed it and bought another better more rust free car.. And built it from the bottom up. ..doing it as right as I can.. Next project is the exhaust, I'm running 2 ½" dual exhaust straight out the back.. You can check out my website... http://www.v6spider.comRedline wrote:I quite like the idea of a V6 Spider.
