I messed up - marked the bags that the brackets were in and then cleaned both at the same time - do not know which one is which?
They are different and cannot find which one goes to which side.
Can someone help me out with photo or explanation as to whether they are to lean back or lean forward?
Thank you so much. John Mc.//
Motor mount brackets - unsure which one goes to which side?
- Your car is a: 1970 Fiat 124
- 124JOE
Re: Motor mount brackets - unsure which one goes to which side?
i think they lean forward
ok i was wrong AGAIN
If yours have holes on the side, the one with two holes in the side of the bracket goes on the drivers side. The two holes are for the starter support bracket.
