Damper pulley nut size
So Cal Mark is right a 1 1/2" works. I Just removed and changed my timing belt and used 1.5" socket and it worked perfectly (thanks to liberal coatings of Liguid Wrench). I tried to buy a 38mm socket and I couldn't get one easily.
One tip the tensioner spring nut that holds the rear timing cover does NOT need to be removed! My directions said not to remove it but loosen which I did and it still wouldn't slide out! The next line said to remove it so I removed it thinking that doesn't make sense. Anyway... I removed it... bad idea! It came off easy for sure but I had a tough time getting the spring back in place. BEWARE! Experience rules!
Billl
Billl
Bill, How did you hold the motor from turning ? I have got things all stripped out ( hoses, radiator etc) but it has to sit in my garage till I work out how to loosen that front pulley. My cars' done 78000 miles so may have had a belt done at some time but EVERYTHING is so darn tight. I suspect possibly a mechanic with "power wrenches" has been at it ?
- spidernut
You can buy or make a tool to lockdown the flywheel. I personally used a piece of angle iron and bent it carefully to fit the teeth in the flywheel. It worked like a charm.
John G.
1977 Spider (Sold 2017)
1979 Spider (Sold 2015)
1980 Spider (Sold in 2013)
1981 Spider (Sold in 1985)
Re the comment re old design timing covers, I'm not sure why but they now have an additional tin shield. Perhaps it is the additional loads that might be put on the front pulley with AC and anti smog air pumps etc that needed an increased nut load but the older (1972) 1608's were only torqued up to 88 foot pounds!
that is correct. I don't believe that the extra tin shield was used until later models.
honestly, this was the first belt change w/out removing the pulley. i nearly gave up on doing it this way as the clearance between where the belt needs to go and the pulley is very slim. But, the pulley was not budging w/out getting a second set of hands in the engine bay.....which are not available. So, i persisted until i got the belt in place.
as a result, I too am looking for alternatives, is there really clearance for an impact wrench? or, as i've heard, does a hole need to be drilled in the nose?
my '80 had the shield installed, but when I replaced my timing belt, i left the shield off.....i understand that many owners did just that. just because the book says the part is there, don't autmatically believe it to be true w/out inspection.
