I have a 1976 Spider with the original steering wheel (wood) that is attached with a single nut in the center. I want to replace this with a steering wheel that I think is from a later model Spider that have a smaller horn button and 6 holes around the center hole.
I assume that some type of adapter is needed to mount this steering wheel in place of the stock one? Any advice on how to do this is appreciated.
Thanks,
Randy B.
Replace/upgrade steering wheel
Re: Replace/upgrade steering wheel
randy, after you replace that wheel, what are you doing with the old one? if it isn't cracked....and you want to part with it....could i have a shot at relieving you of it? i am willing to throw shekels in your direction for a quality wheel.
The current wheel does have a small crack in it (perhaps a 1/8" gap) in the 6 o'clock position. Once I can get the new one installed, I was going to toss out the old one becuase of that but if there's interest, I'd be happy to send it on for just the cost of shipping.
Randy B.
Randy B.
since you are changing the wheel, does that mean you are changing the horn button as well.
If you are willing, i'd take both the wheel and the button for the cost of shipping. Let me know when you are ready, and I can either pay pal or personal check to you. send me an email... mbouse@chartermi.net when you are ready to go. zip code is 49036
I have a hub on order from a local Fiat source (Fun Imported Auto and Toys in Rockville, CT). Once I get the new wheel installed, the old wheel and hron can be yours.
Randy B.
Randy B.
Mike,
I have the steering wheel replacement scheduled for next week (6/28). If that goes successfully, I'll contact you regarding sending the old one out to you.
Randy B.
Randy B.
SA - weeet !!
I will be heading to FFO on the 10th of July...and starting the weekend before...will be really busy getting ready to go. So, if you ping me and I don't respond - that is only because i'm distracted. send me an email to mbouse@chartermi.net and i will give you the pertinent details. zip code is 49036. i can do pay pal or personal check.
Mike, did you do this? Wisconsin Steve has a wheel that might be just like this one and I'm interested in doing it too.
