I'm removing my yoke that is on the output shaft of the transmission, prior to the flex donut. I'm trying to get the correct measurement in mm of the nut holding the yoke on, so I can remove it.
I think it's about 33mm or 34mm
Anyone have an exact number?
Size of nut holding the yoke on - output shaft in mm?
Re: Size of nut holding the yoke on - output shaft in mm?
The yoke retaining nut is 32mm.
