What type of oil should I use on my Fuel Injected 2000 l engine? Synthetic? What do you guys use?
Thanks in advance
What type of oil to use in my 80-2 Fuel injection engine?
- Your car is a: 1981 Fiat 124 Spider FI
Re: What type of oil to use in my 80-2 Fuel injection engine?
Shell Rotella 15-40 DIESEL seems to be the most popular, has the right combination of additives to protect these engines.
Pete
Pete
Why Diesel oil? And how many quarts do I need?
Rotella 15/40 is closest type of oil to what the car was made to run on. If you do not have new gaskets and seals you might want to stay away from synthetic. It has a way of finding the week spots and leaking out even more on our older engines manufactured with less precise machining. 4 quarts on level ground should do it.
82 Fiat Spider 2000
03 BMW M3
07 Chevy Suburban
82 Fiat Spider 2000
03 BMW M3
07 Chevy Suburban
Yes put in 4 quarts to start, run the engine for a little while and then top it up, checking the dipstick. I believe that 4-1/3 quarts is the spec, if you also change the oil filter at the same time. I have been running it a little higher, like 4-2/3 or even a little more, with no ill effects. (no leaks, no splash backs up the tube, no oil in the crankcase vent line) The engine seems to run smoother with the oil level a little higher. Might be my imagination though. This Winter's change went back to 4-1/3 and will see if I notice any difference.
Pete
Pete
- Your car is a: 1981 Fiat 2000 Spider
Do you use it with or without a zinc additive?
- aevansgatech
The rotellas are good oils. Interestingly most of us in the new Abarth community use Rotella 5W-40 on the turbo engine.
I'll switch over to 15W-40 on the Spider!
1979 Spider 2000 (gone)
1984 Pininfarina Azzurra (for sale)
1982 Spider 2000 (here to stay)
- toplessexpat
One of the reasons we use the Rotella is it means you don't need an additive.NobleCause wrote:Do you use it with or without a zinc additive?
- Odoyle
I run Castrol GTX 5W-30 along with "cam shield" zinc additive from Mark.
- azruss
Im a big believer in synthetics. I was at a truck show one time where the Amsoil booth had a hot plate and a dry ice chest with both synthetic and normal motor oil. On the hot plate, the standard oil turned to soot. In the ice chest it turned to molasses. The amsoil stayed the same color and viscosity in both tests. I've heard you do the greatest wear to your motor in cold startups. Not that i worry about that in the Arizona blast furnace. I do worry about the excessive heat here. i like the idea of an oil that won't break down in the heat. I suspect with a low use car and lots of days between oil changes, the synthetic will not age as fast as conventional oil.
I have always and still do use Castrox GTX 20-50 in all my old Fiats. The amounts mentioned seem correct. When I used to run track days I would overfill by one quart to keep the motors from oil starvation in hard turns but not necessary for street driving.
carl
carl
