DFEV advice, please
quanta2
DFEV advice, please
Post by quanta2 »
I screwed up and changed the set screw on the secondary barrel on my new DFEV. Does anyone know what the factory setting is on the butterfly opening? In thousands of an inch? I know it needs to be slightly open.
bluespider262
Your car is a: 1979 Spider
Re: DFEV advice, please
Post by bluespider262 »
.002"
If you can tell it's open its too much. It's just enough to not have the blade jam in the bore essentially.
quanta2
Post by quanta2 »
Perfect, thanks!
