I think this came off the brakes?
JohnMc
Your car is a: 1970 Fiat 124
Post by JohnMc »
Putting brakes back on after suspension. Took off the caliper bolts and disk brake assembly (did not disassemble calipers at all). Then later saw the thick spacer/washer/bearing in photo. 15.8 mm outside diameter, 10 mm inside diameter and 5.4 mm thick.
Any idea where this came off of? Much thanks.
Re: I think this came off the brakes?
looks like a spacer from the lower shock absorber bolt
JohnMc
Post by JohnMc »
Mark, you are absolutely right - this came off the shock. Thank you so much!!
I would feel more foolish - but am too happy to feel bad :D
