Carbon Buildup In Cylinder Head
joelittel
Post by joelittel »
I'm building a performance 2L and plan to use my existing cylinder head on the new block. While everything is easily accessible to me I'd like to address as many problems/issues as I can.
Is this a normal amount of carbon buildup for a fuel injected '80 with stock compression and some performance mods, ie. header, cams & cylinder head? Or is the carbon buildup an indication that something is off?
djape1977
Re: Carbon Buildup In Cylinder Head
Post by djape1977 »
that engine is burning oil.
quite a bit of it
joelittel
Post by joelittel »
Good to know.
Should I clean all the carbon off the head before it goes on the new block?
RRoller123
Post by RRoller123 »
new head, rebuilt with new seals, guides, etc?
weengra
Your car is a: 82 Spider 2000 + 76 128 Sedan
Post by weengra »
Anything less than a full rebuild of the head is a false economy. It should be disassembled, cleaned and checked for straight/flat, all worn parts renewed.
Bill Barker
Madison, Wisconsin
1982 Spider 2000
1976 128 Sedan
weengra
Post by weengra »
Bill Barker
Madison, Wisconsin
1982 Spider 2000
1976 128 Sedan
131
Post by 131 »
weengra wrote:Anything less than a full rebuild of the head is a false economy. It should be disassembled, cleaned and checked for straight/flat, all worn parts renewed.
X3. Complete waste of time putting that head on a new bottom end, get it overhauled.
Mick.
joelittel
Post by joelittel »
The head is only 1 season old. AR refurbished it for me last year, which is why I was so surprised by the carbon buildup when I took it off the old block.
djape1977
Post by djape1977 »
then no rebuild is needed.
take it to a machine shop for a wash. they will have a machine for washing those. basically like a dishwasher.
carbon bildup on intake can come only fron crankcase breather, and that's a sign of worn sleeves/piston rings
joelittel
Post by joelittel »
Thanks djape1977 I'll get it cleaned.
Incidentally, the aluminum piece that connects the crank breather hose to the block, seen in center of original picture, was filled with a tar like goo. Literally filled with it.
I knew my old block looked "rough" when I put the new head on it, but I didn't understand how rough it was. It never smoked, but looking back I suppose it did drink a little too much oil.
I'm glad to be going through this experience. I feel as though I've learned more about my car since October than I had in the last 5 years of ownership.
baltobernie
Post by baltobernie »
joelittel wrote:The head is only 1 season old.
That looks like some corrosion in the coolant passage as well. Was the cooling system cleaned when you rebuilt last year?
joelittel
Post by joelittel »
I did flush the cooling system with a kit from my local parts store. At the moment I don't recall the brand of flush kit I used.
But that's all I did.
Are coolant passages normally cleaner than mine?
djape1977
Post by djape1977 »
yes, they should be.
what kind of coolant did you use after flushing the system?
joelittel
Post by joelittel »
Green stuff from auto zone. It may have been Peak brand. It was definitely the 50/50 premixed type though.
djape1977
Post by djape1977 »
needs to be blue or pink stuff
green is for engines with cast iron heads
