Auto choke back side spring
versuspop
Post by versuspop »
Hi all,
I am trying to figure out how the wound spring and plastic piece on the back side of the choke should be oriented. You can see from the pictures that the business end came loose, but it did so accidentally. Did not see the orientation!!
Ian
versuspop
Re: Auto choke back side spring
Post by versuspop »
In other words- what does the spring that is wrapped around the white plastic piece attach to?
Ian
versuspop
Post by versuspop »
Or- is there a name for the little plastic cam, so that I can look for images?
Ian
