Any idea what these are?
jfrawley
Your car is a: 1982 Spider
Post by jfrawley »
Found them in my 1982 Spider. PO didn't know what they were for. Anybody?
http://s303.photobucket.com/albums/nn12 ... ese001.jpg
John Frawley
Frederick, MD
1982 Spider
http://www.dcfiats.org
perthling
Your car is a: 1974 124 Spider
Re: Any idea what these are?
Post by perthling »
Look like the catches for the quarter windows. Round flat part is glued to the glass, angled piece rotates around round piece and locks window closed against window frame.
_______________________
Perthling
1975 Fiat 124 CC (project)
1969 Fiat 124AC (project)
http://www.fiatlancia.org.au
mdrburchette
Post by mdrburchette »
They look like some type of vent window latch but not for a Spider.
mdrburchette
We posted at the same time! I wondered why a different message came up when I hit 'submit".
pope
Post by pope »
Those are the window catches for an 80 or later Spider. I dont know what earlier models used them.
rlux4
Patron 2022
Patron 2022
Post by rlux4 »
Yup. Pope is right, here's a picture of one on my '82.
Ron
Ron Luxmore
rlux2n2@gmail.com
jfrawley
Post by jfrawley »
Well that solves that. Thanks.
John Frawley
Frederick, MD
1982 Spider
mdrburchette
They changed the design? Do they stay on better? :?
jfrawley
Post by jfrawley »
I found mine in the glove box, so I guess not.
John Frawley
Frederick, MD
1982 Spider
mbouse
Post by mbouse »
you will find that Fiat did indeed change the style. at our garage, the '78 is the old fashioned kind where you had to depress a button to unlock the latch before turning. I think that is the style you are thinking of Denise.
The '80 has the style shown in the picture on this post.
They do NOT stay on any better, still being glued in place. I have glued the passenger side on my '80 so many times i have lost count. It resides in the glovebox now, on a more-0-less semi permanent basis.
ga.spyder
Post by ga.spyder »
I was gonna ask if anyone knew of a glue that would keep them on...apparently not.I tried twice with mine ,which now live in my parts box.
Craig
Craig Nelson
Fling It Around Turns !
pope
Post by pope »
Mine have never come off since new. I open the window almost every time I drive the car and flip the windows all the way open. I think you might have to use a different brand of adhesive. I think Permatex makes a professional one. Are you guys using the little triangle shaped glue that is found in every store? Surface must be perfectly clean and oil free, with all old residue carefully scraped off. Better bet is the auto glass stores. I think they have a glue that is UV light activated (purple light) and should not be too expensive for them to do it.
HOLLYWOODSPIDER
Post by HOLLYWOODSPIDER »
I assume y'all are using Rearview Mirror adhesive. That's what I used on my BMW, and it worked great. BTW, bmw 2002s use the same window latches as the early (pre-'80?) spiders and coupes.
rlux4
Patron 2022
Patron 2022
Post by rlux4 »
I'm assuming you guys have tried mirror base adhesive, correctly applied. It does need to cure for a few days to get to full adhesion.
Also, considering who is posting here, this is not aimed at you Craig or Mike, but I've seen people pull the wing window shut with the latch, this is how I believe any of these come loose. A PO used it as a pull. The window needs to be pushed shut from the outside, then latched, to keep this from happening.
Ron
Ron Luxmore
rlux2n2@gmail.com
Tappy
Your car is a: 124 spider 2000 1979
Post by Tappy »
someone told me to duck tape the latches , however the duck spoiled the view a bit ....
FineItalianAutomobile TechnologyImage
