Order valve shims
AVIANO84
Your car is a: 1984 Pininfarina Azzurra
Order valve shims
Post by AVIANO84 »
Looking for suggestions on ordering valve shims for exhaust valve based on present gaps with original shims in place. I know the right way to order is to remove each shim get measurement and in my case ad to get to min. .020 of gap, these are the gaps I have per cylinder # 1-.030 , #2- .020 will leave , # 3-.028 and #4-.030 , I have valve noise as we speek at idle but the car runs fine
klweimer
Re: Order valve shims
Post by klweimer »
It's impossible to know what shims you need unless you know the thickness of the current shims.
AVIANO84
Post by AVIANO84 »
ok thanks
klweimer
Post by klweimer »
When I rebuilt my head, I made a simple Excel spreadsheet that you can use to figure out what shims you need. PM me with you email address if interested.
