Transmission capacity
I am in the middle of changing out the transmission fluid on my 1976 manual 5 speed. I drained out about 3/4 of a quart. The manual says it should hold about 1 3/4. Am I missing an additional drain plug somewhere. I drained it from the plug in the middle of the pan( allen head ) and am going to fill it through the plug (17mm bolt) on the passenger side of the tranny . I don't seem to be leaking anywhere. Is it possible the previous owner just dident fill it enough. Thanks in advance
Re: Transmission capacity
There is another, small drain plug on the rear side of the transmission, that will drain a little out too. Apparently there is an internal baffle that catches some at the rear. I got maybe a cup or 2 out of there when I changed mine. Sorry I don't have a pic, but I bet someone else does.
Pete
Pete
I just changed mine, and just drained the center plug. It took about 1 1/2 quarts.
1979 Fiat Spider (since new)
1999 Honda Shadow VLX 600
Do the rear plug too! The fluid that came out, even though a relatively small amount, looked nothing like transmission oil.
- focodave
1970 MGB GT (my other hobby)
- joelittel
I thought that with the transmission you simply filled it until it starts to overflow from the fill hole, so unless you're filling it from a higher point you can not over/under fill. That being said, only getting 3/4 quart out would be a concern for me.
Good thing you're addressing the problem now.
I've also read that if you drain the smaller baffle section in the back it's a good idea to top off the transmission fluid again after a short drive b/c you can't or won't be able to fill that back baffle area through the fill hole on the first attempt.
- Your car is a: 1982 Fiat 124 Spider
Perhaps it was low on fluid to begin with. Were you experiencing shifting problems?Welder wrote:I am in the middle of changing out the transmission fluid on my 1976 manual 5 speed. I drained out about 3/4 of a quart. The manual says it should hold about 1 3/4. Am I missing an additional drain plug somewhere. I drained it from the plug in the middle of the pan( allen head ) and am going to fill it through the plug (17mm bolt) on the passenger side of the tranny . I don't seem to be leaking anywhere. Is it possible the previous owner just dident fill it enough. Thanks in advance
